73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> View alignment on Multiple Sheets
79 Posts No Rating |
It seems that there is now precise way to lock views on a sheet into the same location on different sheets. For example multiple levels of a floor plan on separate sheets. I've seen multiple posts on this subject, but was wondering if this is possible in Revit 2009? Thanks for your time.
----------------------------------- HuntFlo |
![4 Stars: 19 Votes](/images/stars_4.gif) |
You can't snap on viewports, so you cant do it exactly. You can draw some lining up marks in the sheet family and give them a visibility parameter that you can switch off after aligning the viewports. It won't be exact, but if you zoom in close you can place them quite accurately.
Same View on Multiple Sheets |
Sun, Aug 28, 2005 at 5:51:36 PM
Want to have typical washroom elevation on multiple sheets |
Fri, Oct 23, 2015 at 11:20:00 AM
Multiple sheets from same floor plan view with different scales? |
Fri, Aug 1, 2008 at 12:01:43 PM
Engineering Stamps on Multiple Sheets |
Wed, Apr 8, 2015 at 11:13:44 AM
Drafting Views on Multiple Sheets-Revit 2008 |
Wed, Sep 3, 2008 at 3:11:48 PM
Members: | 2016919 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
