50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Modifying floor slabs/foundation footings??
Wed, Aug 26, 2009 at 3:31:33 PM | Modifying floor slabs/foundation footings??
HGL5
So I am trying to recess a masonry wall into the floor slab, but I am unsure of the best way to go about doing this and would really appreciate some guidence.  Currently what I have done so far is created a floor on the interior perimeter of the exterior wall, then I created a floor using the exterior perimeter of the exterior wall. This gave me the recess I was looking for. Next I attached a footing to the floor which used the exterior perimeter of the wall.
 So this kinda works.... except I get a blck line which seperates the two floors as indicated on the attached picture. How can I merge these two floors together to get rid of the line, or is their another way i should be going about this.
 Im using revit 2010 btw. Thanks for any advice.
Wed, Aug 26, 2009 at 3:36:00 PM | Modifying floor slabs/foundation footings??
4 Stars: 203 Votes
In that section view use the "Join Geometry" to join the two floors or use the "linework" tool with "invisible lines" to get rid of that line....
Wed, Aug 26, 2009 at 4:59:35 PM | Modifying floor slabs/foundation footings??
HGL5
Thanks Typhoon, worked like a charm!
Thu, Aug 27, 2009 at 3:35:33 AM | Modifying floor slabs/foundation footings??
4 Stars: 203 Votes
I know that, your Welcome...
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
Shape Editing Tab for "Foundation Slabs"
Thu, Jun 26, 2014 at 7:28:20 AM
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Page generation time: 10.5376
