129 Users Online (130 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Copy Multiple (RA 2010) default?
Mon, Aug 24, 2009 at 1:12:13 PM | Copy Multiple (RA 2010) default?
hyoctane
This is borderline ridiculous -- I've been working with Revit since version 7 (I'm on RA 2010 now) and I still can't believe that Autodesk hasn't found it necessary to default copy multiple. They found it necessary in AutoCAD, but not Revit. Is there a work around or some internal programming/macros that will automatically default copy to multiple?
Wed, Jun 30, 2010 at 3:40:15 PM | Copy Multiple (RA 2010) default?
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
I am in 2011 Structure and it is the same thing.  I find it quite annoying.  I don't think they even have a "Copy Multiple" command.  I looked in the Keyboard Shortcuts menu and did not see anything for it.  Please tell me I am wrong!
 I use Autodesk Revit Structure 2011
 My songs: http://nkat.newgrounds.com
Wed, Jun 30, 2010 at 4:10:15 PM | Copy Multiple (RA 2010) default?
The options bar folks... remember that?  Right below the ribbon - pick your object - the copy icon ... and then CHECK THE MULTIPLE BOX on the options bar.
Wed, Jun 30, 2010 at 4:19:15 PM | Copy Multiple (RA 2010) default?
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
You are right as usual.  I am so entranced by the Ribbon as I came from RS 2008 that I forgot about that Options Bar.  Thanks.
Wed, Jun 30, 2010 at 8:25:02 PM | Copy Multiple (RA 2010) default?
TomDorner
4.5 Stars: 25 Votes
Revit remembers the last option of the command issued.
If you want the copy command to default to multiple, then open your template file, issue the copy command, check the 'multiple' box on the options bar. [hint: you will need to actually copy an object.  erase them when done before saving your template].
Now when you start a new project the 'multiple' option for the command will be selected by default.  However if at anytime in the project you uncheck the multiple box, then it will revert to the single copy option.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Jul 1, 2010 at 9:28:59 AM | Copy Multiple (RA 2010) default?
hyoctane
I appreciate the heads-up regarding the checkbox in the options drop-down toolbar; however, your answer doesn't answer my original question.
I shouldn't have to check a box to "copy>multiple" objects. I know the checkbox is there (it always was an option), but I'm looking for a way to force Revit to default copy>multiple to ON. Even if I am working in a project, save, close and re-open the project, the default copy>multiple is back to OFF (unchecked).  It shouldn't be an option; it should just be ON by default, similar to AutoCAD.
Any other ideas or suggestions?
Thu, Jul 1, 2010 at 12:12:43 PM | Copy Multiple (RA 2010) default?
TomDorner
4.5 Stars: 25 Votes
Your choices at this time are:
1.  Accept Revit for what it is as it will not have a copy multiple option anytime soon without checking the 'multiple' box on the options bar.
2. Abandon Revit and go back to using AutoCAD.
Personally to me this is such a little thing to focus on in light of all the other benefits of using Revit/BIM.
Tom
Fri, Oct 24, 2014 at 2:51:54 AM | Copy Multiple (RA 2010) default?
Dafpfy
3.5 Stars: 11 Votes
any progress on setting copy multiple as default?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Oct 24, 2014 at 7:21:25 AM | Copy Multiple (RA 2010) default?
None that I have seen.
Fri, Oct 24, 2014 at 9:20:03 AM | Copy Multiple (RA 2010) default?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Yeah, nothing has changed, but here’s a little old trick that I found extremely useful. You can copy an object (multiple times or not) by dragging it while holding the ctrl key, and the copied object is visible during the process vs just blue dashed lines when using a copy tool.
Copy / Multiple -- Default Setting
Thu, Sep 18, 2008 at 3:39:03 AM
Revit 2010 Extruding Multiple Surfaces all at once?
Mon, Feb 15, 2010 at 10:59:05 AM
11
Sheet Scale w/ multiple scale views - cahnge the default?? RAC 2010
Mon, Aug 29, 2011 at 7:58:12 AM
Cannot replace panels in a Curtain Wall, then copy
Mon, Apr 12, 2010 at 1:37:20 PM
Revit 2010 default highlight selection color
Fri, May 8, 2009 at 5:11:01 PM
Page generation time: 7.0168
