65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Footing Tag
Mon, Aug 24, 2009 at 12:00:41 PM | Footing Tag
voglerb
I'm wanting my footing tag to rotate with the footing componet.  I've got alot of 45 degree walls in my project and would like to have the tag rotate 45 degree's along the footing line.  I've tried to edit the footing tag family and checked the rotate with componet but nothing happens.  Does it simply not work with footing tags?
Thanks
Tue, Aug 25, 2009 at 12:06:55 PM | Footing Tag
jhayden
jhayden Avatar
I'm working on a project where the strip footings are at several different angles. Apparently Revit has not written the program to rotate the foundation tags as they have for the walls, so I've been using text until this is fixed. If all of you footings are at 45 degrees, you can edit the family tag and rotate the text in there to 45 degrees. Try using the attached tag family for your foundations. You can control the way the text slopes by choosing horizontal or vertical from the drop down box. HTH.
Jeff
How do I read Top of Footing for tag
Thu, Jul 19, 2012 at 9:37:09 PM
Insertion Point for a tag-Revit Structures 2009
Tue, Feb 10, 2009 at 6:24:43 PM
Top of Pel Cap Tag and Arrowheads with an integral on the end of it.
Wed, Aug 27, 2014 at 2:51:22 PM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:13 PM
Page generation time: 0.4406
