27 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Links
Sun, Aug 23, 2009 at 5:25:23 PM | Links
KiwiRoss
KiwiRoss Avatar
4 Stars: 18 Votes
Hi,
Once a model is put together with several linked buildings, the file is large and when opening it takes forever to load etc. I would like to cut the links, but leave those buildings in place, albeit having no links.
Can this be done?
Thanks for assistance that anyone can shine on this.
Mon, Aug 24, 2009 at 7:04:28 AM | Links
3.5 Stars: 401 Votes
The links are your other buildings so if you cut the links, you will not see them.  The file size should not be much larger because of any links but it may take longer to load.  You can manage that load through your links and also if you have set them up in worksets.
If you told us a little more, maybe we could suggest better options.
Wed, Jul 28, 2010 at 3:52:29 PM | Consolidating Links
mstanhall
Hi.
I am trying to consolidate 4 linked files into one file. The links are individual components of the same building- much like worksets. I have just been tasked with completing this project, and the model is a mess- full of circular links, no worksets, and other wierd things. It's impossible to get anything done.
Short of copying one entire file, and pasting it in the other (which it won't let me do because of the circular links), is there any other way to get all of my information in one file, and then set everything up on worksets like it should have been done from the beginning?
Thanks!
Micah
Wed, Jul 28, 2010 at 7:07:06 PM | Links
KiwiRoss
KiwiRoss Avatar
4 Stars: 18 Votes
I build up construction camps - each building is a Revit file of 50 to 60 Mb in size.
It is not uncommon to have anywhere from 50 to 300 buildings in one camp, one file.
I want to import several buildings, cut the links then copy and paste more of the same with in the main drawing, So cutting the links would stop the reloading sequence when opening the main drawing with lots of buildings in it.
I will sometimes create a smaller file of the the buildings by creating just building shells - Roof, walls, floor and foundatons - just to end up with a small building file for impoting into the main construction camp file - but still want to cut the links.
Any suggestions.
 Ross again
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
*URGENT * - Worksets & Links
Mon, Oct 12, 2009 at 5:51:32 PM
MANAGE LINKS
Tue, Nov 10, 2009 at 7:41:25 AM
Save to Central or Revit Links
Tue, Sep 4, 2007 at 2:56:57 PM
Inserting Links
Fri, Mar 17, 2017 at 7:44:17 AM
Page generation time: 0.3019
