Forums >> Revit Building >> Technical Support >> Can't insert doors/components in level
2 Posts No Rating |
I'm working on a multi-level house, and when I try to insert a door I am told that "Can't cut instance of 30" x 84" out of Wall." Also, when I go to insert a component, it shows up on the First Floor Level, and I have to copy to clipboard and paste to the basement level. What am I doing wrong? Whenever I go to the basement level's properties and click on "View Range" it tells me that the Associated Level is the First Floor. Is this the issue? How do I change that?
Your problem is with your views. They were not created in association with the level. In REVIT, you don't just copy a fllor plan, give it a new name and change it's view range. Learn to use your HELP because it is very good in REVIT. Here is what it says: Creating a Plan View - Click View menu New Floor Plan, or on the View tab of the Design Bar, click Floor Plan.
- From the New Plan dialog, select one or more levels for which you want to create a plan view.
- If you wish to create a plan view for a level that has an existing plan view, clear Do not duplicate existing views.
- For Scale, select an appropriate view scale for the new view.
- Click OK.
2 Posts No Rating |
Thank you! This is the solution that I finally found when googling the issue last night. I suppose I just didn't know the "correct" question to ask my help.
1 Posts No Rating |
Very helpful tip. I just came accross this problem and I was chasing my tail to try and fix it. Made a new floor plan from the pull down menu and the problem resolved itself... such an odd problem
everything inserting on the wrong level? |
Mon, Jul 9, 2012 at 11:09:27 AM
Components on Level are Grey |
Wed, Apr 17, 2013 at 12:56:06 PM
Furniture, Doors, Casework, In Place Components have x-ray, see through properti |
Wed, Jan 25, 2012 at 4:07:10 PM
Can't insert door to wall |
Thu, Oct 8, 2020 at 6:46:39 AM
Doors flip on insert |
Mon, Feb 10, 2014 at 1:50:08 AM
Members: | 2115152 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
