Forums >> Revit Building >> Technical Support >> Topo slopped pad (parking lot/road)
2 Posts No Rating |
I am using revit 2009. I need to create a pad that merges into the top of my topo grade. I have created a sloping pad that slopes up about 10 feet but I have realised that at the top of my pad, I am having major issues aligning my head end of my sloped pad with the original topo... what am I doing wrong here? Any assistance will be greatly appreciated... plz see image attached
Pads have 'thickness' and they remove material from toposurfaces when they are within the toposurface whether the pad is visible or not. I looks to me from the one attached image that the pad visibility is turned off leaving the void. Need more descriptive images. (don't select the pad)
2 Posts No Rating |
First off, thanks dgcad for the prompt response! Let me back it up a bit (I went ahead and attached 3 images for visuals):Initially, I designed and drew all the buildings for my project2nd - I was then given the data for the entire lot so I linked the buildings to the lot 3rd - later on, I received the topo data for the project (after creating project with parking components --(see site plan image)4th - Created topo from survey data - (see contour image) this is when I realised there was a rather moderate terrain (about 20' slope) Problems:1- Realising there was a slope, I needed to figure out a way to merge my contoured data to my flat data (unsuccessful after many attempts) Suggestions will be wonderful here.2- I started working on the contoured topo but cant get the pads to blend to form a smooth flowing road/parking lot (see site plan pad problem image) The result is a cliff that resembles an area for a retaining wall. what am I doing wrong here?
Ok, looks like perhaps the pad 'Level' and or 'Height Offset from Level' need to be adjusted in the 'instance properties' of the pad. Also make sure the 'pad' visibility is turned on (which is view specific).
Edited on: Sat, Aug 22, 2009 at 11:07:50 PM
just a shot in the dark here, but could you use a sloped floor with a thickness and material designated for the floor type itself?
What's the best way to make a parking lot |
Mon, May 7, 2007 at 2:58:27 PM
slopped pad |
Fri, Jun 23, 2006 at 9:42:33 AM
Tag for Parking Areas- lot # and total spaces in lot |
Thu, May 22, 2014 at 10:37:15 AM
Topo is struggling |
Tue, Aug 15, 2006 at 9:24:02 AM
Topo surfaces on top of structures |
Sun, May 4, 2008 at 4:59:39 AM
Members: | 2115418 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
