30 Users Online (28 Members):
Forums >> Revit Systems >> Tips & Tricks >> many viewports
16 Posts No Rating |
May you help me How to take many viewports in revit?
Your question is unclear.... please, explains better what do you realy want....
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
I think you just need to 'tile' the windows as per the attached image. Or type from the keyboard 'wt' (window tile). In 2009 you can use 'wt' or look under the 'windows' pulldown for 'tile', if I recall correctly
Edited on: Sat, Aug 22, 2009 at 10:31:18 PM
Very great. Thanks a lot
In REVIT, viewports are the views that you place on sheets just like AutoCAD but to tile views on your screen your are really tiling 'windows'.
Thank you for help. May you help me one more time: How to change the colour of a line in revit 2009? The line has default green color. I want to change it from green to black but I don't find anything in element properties to edit it. Thank again
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Be careful - do you know what kind of line this is. In Revit, we use model lines and drafting lines. The out of the box model line is green. That line will show in all model views. Detail lines are view specific. To change this line color, look under settings - line styles.
Thanks
Edit Visibility Graphics in multiple viewports? |
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet |
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell |
Thu, May 23, 2013 at 2:28:19 PM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports |
Fri, Jan 13, 2012 at 11:29:51 AM
Viewports! |
Mon, Mar 31, 2008 at 8:20:25 AM
Members: | 2025978 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
