92 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> can't view file properties - central path
Fri, Aug 21, 2009 at 10:00:39 AM | can't view file properties - central path
jamiew
I am detaching a local file from central and want to see if I did it correctly.  Isn't there a way to view the path of the central file?  I can't tell which central file I am attached to.  I'm afraid to save to central, because If I didn't detach properly, I will be overwriting a drastically changed file.
 Revit 2009
Autodesk Revit MEP 2015
Fri, Aug 21, 2009 at 10:16:35 AM | can't view file properties - central path
3.5 Stars: 395 Votes
When you open a central file detached... or a local file detached ... then it is detached!  How can it show you a central?
If save to central is not allowed then you have a detached file.
Fri, Aug 21, 2009 at 12:53:04 PM | can't view file properties - central path
jamiew
Sorry, maybe I used the wrong word.  I was working in a local copy of a central file.  I made some extensive changes that I did not want to save back to the central.
So I did a save as, selected "make this a central file after save."  I was hoping to make an independent central file that was no longer linked to the original central file.  I just want to check and make sure that it worked before I save to central again.
Thank you!
Fri, Aug 21, 2009 at 1:29:50 PM | can't view file properties - central path
If you use the option save as & make this a central... then you now are working in the central at the location you saved to.. you should immediately do a save as to your local directory and you will now be in your local linked to this new central and you never closed a file   ... got it?
Fri, Aug 21, 2009 at 2:34:53 PM | can't view file properties - central path
jamiew
Thank you!  I feel better now!
Central File Path on a local file
Sat, Oct 24, 2015 at 10:21:20 AM
CENTRAL FILE PATH NOT FOUND HELP HELP!!!
Sun, Feb 22, 2009 at 12:35:49 PM
Plot stamp: Set file-path to Central
Tue, Jun 7, 2016 at 8:33:00 AM
File Path in Titleblock
Wed, Nov 10, 2010 at 10:48:55 AM
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
Page generation time: 4.3835
