Forums >> Community >> Newbies >> Creating Custom Title Block for the Newbie
1 Posts No Rating |
Hi, I'm hoping I post this in the right spot. My company just got Revit MEP 2010, so we're all swimming in new data. Yet it looks like we still have a lot to learn! I've personally never used the program before, so of course I'm picked to create a template. I've got a title block and text, but can't seem to wrap my head around the shared parameters thing. Here is what I've done so far: Create label > click where I want it > Add Parameter > Select a Shared Parameter > Edit > Create > I created a txt file called Shared Parameters > created a new Group > created a new Parameter > named the parameter, choose common for discipline, and text for type > ok > ok > ok > select the new Parameter form the updated category parameters and add it under the lebel parameters > apply and ok > then i load my title block back into my little templete file. After all that, the text is still red and uneditable. I want it to be blue and show up on all my sheets the same. A little help? I appreciate it!
Did you assign that parameter in the project to sheets? ...project? Read you HELP.
1 Posts No Rating |
WWHub, why don't you just piss off for good since you have nothing else to say than 'read your help'. Just fuk off already. You aren't in the slightest helpful in your comments, you obviously detest being helpful...so why be here?Goodbye and good ridence
Edited on: Thu, Sep 13, 2012 at 2:03:28 AM
Edited on: Thu, Sep 13, 2012 at 2:04:58 AM
Edited on: Thu, Sep 13, 2012 at 2:05:26 AM
You are completely out of base, WWhub is one of the best and one of the most helpful people here in RC, there is no one like him.
I was looking your profile and you are a member user since Sept. 2009 (3 years), until now you didn't posted NOTHING, your contribute to this community was ZERO.
And BTW, we'll not tolerate that kind of VULGAR language anymore... (the "F" word...).
This is a professional site for professionals and if you aren't one of them GET OUT.
In the default Revit Templates i couldnt find revit title block |
Fri, May 23, 2014 at 7:22:24 AM
Custom title blocks |
Mon, Mar 24, 2008 at 2:00:45 PM
Font on Title sheet absent from project Title Block |
Thu, Sep 15, 2022 at 12:31:27 PM
How to import my title block from AutoCAD? |
Mon, Sep 10, 2007 at 4:25:44 PM
12
How to link a Revision Schedule on Title sheet with Title Block |
Fri, Jan 11, 2013 at 7:26:27 AM
Members: | 2098622 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
