76 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Create refering view in existing tag in Revit 2010
69 Posts No Rating |
so I have an existig tag and I would like to add a reference to an existing elevation. I have been looking for any information on this but have been thus far unsuccessful. any suggestions?
You actually need two callouts..... One is the one you have ... the other use reference other view. If all the views ... new and existing are on the same sheet, then you can place one on top of the other ... otherwise - the sheet number inside the box is different so you need two distict call-outs
Thanks WWHub: the elevations are all on the same sheet and I started using the method you described, but I figured there was a better way....guess that I should add that to the wish list.
connect to existing [ 1 2 ] |
Fri, Aug 17, 2012 at 9:59:38 AM
20
How to create new Door Tag to our requirement?or edit existing |
Thu, Sep 16, 2010 at 5:23:09 PM
Should i use the existing Revit Model to create a new building addition? |
Tue, Apr 19, 2011 at 8:07:22 AM
arch way/ door way Constraint & tag |
Tue, Aug 3, 2010 at 6:48:07 PM
Detail callout tag... for 2010 |
Wed, Nov 11, 2009 at 11:58:51 AM
Members: | 2030542 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
