78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> structural walls copied from arch
Wed, Aug 19, 2009 at 1:24:29 PM | structural walls copied from arch
iksnawi
when you have a arch system wall and want to just show the cmu only in my plans. the arch wall is based off the center of the system wall also. i cant just use the structural part. is it best to draw my own walls and not use copy/monitor? just use the arch model as a link and background for when i need to see if walls and doors and windows move.
Fri, Aug 21, 2009 at 6:49:56 AM | structural walls copied from arch
You need to work this out wit the architect.  If you need to own the wall then you need to copy-monitor it or add your own over-top and turn the architect's walls off.  Copy-moinitor works but it takes coordination and a high skill level on both ends.
Link in Arch Model's walls instead of copying them into Structural
Tue, Jun 16, 2015 at 1:23:01 PM
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:31 PM
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:35 AM
Arch Walls Block View of Struct Posts
Tue, Feb 11, 2014 at 2:16:48 PM
Shading Structural Walls
Mon, Nov 21, 2011 at 11:21:47 AM
Page generation time: 0.8603
