70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> topo. surfeaces
Wed, Aug 10, 2005 at 1:57:01 AM | topo. surfeaces
Shanzie
Guys/gals, I have a topo surface that varyies in heights all over the site. Now i have to put a carpark which when i go to join the two roads together, there is a 2400 in height diffrents between them. how do i get these two to line up on the site??? Shanzie
Wed, Aug 10, 2005 at 5:13:25 AM | RE: topo. surfeaces
eldados
eldados Avatar
4.5 Stars: 8 Votes
very hard to understand what you are talking about, an image could help a bit... do you create a pad on the site to give you a level area for the carpark?
Wed, Aug 10, 2005 at 7:43:08 PM | RE:
Shanzie
Guys/gals,
Shanzie
I have attach a DWF print to show you guys what i mean!!! (note you will need a DWF viewer to open, it's free from Auto desk web site).
Fri, Aug 12, 2005 at 11:15:46 AM | RE: topo. surfeaces
nivola
Some suggestions: 1. Add a sloped floor 2. Modify the points of your topo surface
Thu, Jan 10, 2008 at 9:59:45 AM | topo. surfeaces
iBoxer
You could simply create a subregion within your overall topo surface between your two roads in the shape of the "connector" that you need. After that you just set the material to Asphalt and you should be set to go. The only problem is that your not going to be to easily achieve a slope on any curbs.
Topo Lines part 2
Tue, Feb 28, 2012 at 10:05:02 PM
topo depth
Wed, Nov 7, 2012 at 2:17:32 PM
14
Invisible Topo
Mon, Jan 27, 2014 at 10:25:30 AM
Drawing lines on 3D topo
Thu, Sep 22, 2011 at 9:29:48 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:02 AM
Page generation time: 0.2550
