71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Detail Component / Filled Region
Wed, Aug 19, 2009 at 10:57:45 AM | Detail Component / Filled Region
Wames
Ok, in 2009 everything worked fine. Since we updated 2010, any and all filled regions (detail component) within my plumbing valves won't appear in the project. Even the valves that come with Revit, such as the butterfly valve. The round circle in the middle should be filled with a solid region but all you see is a circle and no fill.I have tried everything I know but nothing works. In the family, I can see the filled region and it adjusts with the constraints appropriately but still won't appear. I have even tried starting from scratch and still nothing. The one quirky thing I did find was if I changed the visibility settings of the detailed component (in the family) to show in "Fine", it appears in "Fine" view in the project but won't appear in Medium or Coarse. Also, if I change the element properties and uncheck "Use Annotation Scale", the filled region appears. I have tried applying different view templates, different project templates, VG settings, etc. So after exhausting ever imaginable option, I decided to post. I need help!!!!!!!
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:34 PM
Filled Regions in Detail Components
Tue, Jul 17, 2018 at 9:19:35 PM
Filled Region in 3D Plumbing Family
Tue, Jun 12, 2012 at 9:06:05 AM
FILLED REGION IN 3D VIEW OR PERSPECTIVE VIEW
Wed, Jan 26, 2011 at 5:10:06 PM
Filled region within detail family not showing in design option
Sun, Sep 21, 2014 at 7:24:47 PM
Page generation time: 1.1098
