45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> The roof tapering tools need to be available on sloped roofs.
Wed, Aug 19, 2009 at 9:38:53 AM | The roof tapering tools need to be available on sloped roofs.
JsBach
 The tools to make points and split lines to manipulate the thickness of insulation, and thus achieve directional sloping, is needed on more than just "flat roofs". The most common way to achieve crickets and to direct water to drains and scuppers is to thicken the insulation, but the basic overall drainage is achieved by sloping the underlying structure. Revit currently only allows use of these tapering tools on a so called flat roof. In my experience I have not yet seen a "flat roof", it can be done, but I haven't seen it and it's not common building practice. If you were going to try to slope this way, the insulation would be 2 feet thick on even a moderate size building.
 I can always come back in and draft the lines representing these crickets, but Revit needs to make the option to model them correctly if it is going to move forward as BIM.
Wed, Aug 19, 2009 at 10:33:19 AM | The roof tapering tools need to be available on sloped roofs.
Might check out this thread... http://www.revitcity.com/forums.php?action=viewthread&thread_id=17430
Sloped Walls and Multi-Level roofs
Mon, Jun 17, 2013 at 7:08:37 AM
two sloped roof
Tue, Jul 24, 2007 at 8:54:52 PM
Circular Sloped Roof in Revit
Tue, Jul 19, 2016 at 9:43:07 AM
Sloped Roof
Mon, Nov 10, 2008 at 12:40:49 PM
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:45 PM
Page generation time: 3.6686
