39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Cielings need some of the same stacking options as walls.
Wed, Aug 19, 2009 at 9:22:31 AM | Cielings need some of the same stacking options as walls.
JsBach
 I have a condition where an eifs soffit (on sheathing and metal studs) helps form an inset for a storefront section. The walls on the sides are Mfg. stone on metal studs. The eifs needs to stop short of the stone but the sheathing and studs carry on. As of now there is no way to make the different materials end in different places, like you can do with walls. Even though I can draft what I need to show, if this is truly BIM we still need more options like this if we are going to be able to be accurate in materials take offs (and ease of modelling). I don't see how this would be a problem, if they can do all this with walls then I can't see any technical reason why it can't be done with ceilings.
 I considered the option of making two ceilings, the eifs as a separate ceiling placed under the structural ceiling, but this gets awefull messy.
Question about placing cielings
Sun, Jan 27, 2013 at 4:43:28 AM
Stacking Toolbars
Mon, Jul 20, 2009 at 11:42:43 AM
Revit 2009 : Area Separation and Mass Room Stacking and Blocking
Mon, Nov 24, 2008 at 4:23:24 PM
2nd flr walls not lining up with first floor walls
Wed, Jun 16, 2010 at 2:20:42 PM
design options
Wed, Jan 11, 2012 at 7:17:57 AM
Page generation time: 1.2093
