81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Changing elevation tags to Shared Coordinates
Tue, Aug 18, 2009 at 12:56:16 PM | Changing elevation tags to Shared Coordinates
jmorabito
Hopefully this is a simple question...
Originally my project was at elevation 0.00.  It now has been moved to elevation 100.00.  I used to the project relocation tool to move my project up to 100, and then changed my levels to reference the "shared" coordinates.  My foundation tags are still referencing the old 0.00 elevation (project elevation I think, if I am understanding correctly).  So my question is, how do I change my structural foundation tags to reference the "shared" coordinates? (eg. display 96.33 instead of 3.67)
Thanks.
Tue, Aug 18, 2009 at 1:12:07 PM | Changing elevation tags to Shared Coordinates
You can edit the units of this in the family.  Pick the label then in the GUI click on the parameter then the #(Hand) icon at the bottom.
Tue, Aug 18, 2009 at 1:21:53 PM | Changing elevation tags to Shared Coordinates
jmorabito
The family already is unchecked where it says "use project parameters."  I am not trying to edit the units.  I am trying to change which set of coordinates the family references.
Thu, Aug 20, 2009 at 8:44:44 AM | Changing elevation tags to Shared Coordinates
Karlosthemessiah
can i presume your using spot elevations on your foundations
Thu, Aug 20, 2009 at 8:48:06 AM | Changing elevation tags to Shared Coordinates
jmorabito
Yes we are using spot elevations.
Thu, Aug 20, 2009 at 8:53:23 AM | Changing elevation tags to Shared Coordinates
Karlosthemessiah
select one of your spot elevations, go to element properties, select edit/new. scroll down to elevation origin and change that to shared.  that should do it mate
Thu, Aug 20, 2009 at 8:59:54 AM | Changing elevation tags to Shared Coordinates
jmorabito
i got mixed up before.  I wasn't using spot elevations.  It was some custom family that didn't give many options.  I just got it worked out using spot elevations tho.  thanks.
Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
Wed, Aug 31, 2011 at 5:29:12 PM
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Shared Coordinates
Sat, Mar 6, 2010 at 10:06:14 PM
updating/changing elevation tag types
Wed, Mar 19, 2008 at 9:49:46 AM
Toposurface - CSV import to shared coordinates
Thu, Aug 22, 2013 at 2:59:54 PM
Page generation time: 2.3896
