47 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 Surface Hatch Problems
18 Posts No Rating |
In the projects im working on i have the roof material setup to apply a surface pattern so that in my elevations the Roof shows the corect hatching to match the roof type. This has worked perfectly is prevous versions of revit but since upgrading to 2010 revit seems to disply the roof hatch at a different line weight to the wall hatch. For example in the proejct im currently drawing the roof and walls are both clad with the same colorbond metal cladding and both the wall and the roof are displying at different line wieghts even thourgh the are the same material the roof being lighter (almost halftone). Changing the colour or pattern does not seem to effect this nor can i find an overide in the object styles or graphic overide settings as it seems to occur when the patten is sloping away from the view plane. I spose that i could apply a drafting region to each elevation but this would be very tedous as this is a large job with 7 seperate buildings. Any help would be greatly appreciated.
Surface Hatch Pattern on Topography/Subregions |
Fri, Oct 24, 2008 at 11:30:56 AM
surface pattern hatch override |
Tue, Apr 4, 2006 at 12:28:50 PM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
Removing surface hatch - crash |
Tue, Sep 1, 2009 at 10:48:45 AM
acad hatch to revit fill conversion problems (revit 2009) |
Sun, Sep 21, 2008 at 9:41:31 PM
Members: | 2022326 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
