37 Users Online (36 Members):
Forums >> Revit Systems >> Technical Support >> Alternatives to driving parameters
38 Posts No Rating |
1. Im curious whether or not its possible to make a parameter for a component be editable via the options bar as opposed to going through the element properties. for example how "flow" is editable through the options bar for an air terminal component. or how "width" and "height" and "offset" is there for a duct. 2. and also curious how to make the instance parameter be editiable via temporary text for parameters of a component. similar to having parameters being driven through a Tag but i dont want a Tag. if you dont understand just try insert an air terminal and then select it. youll notice text appear temporarily showing the size of the component. see attached image for reference
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
I do not think either of these two 'wish list' items are possible. 1. Edit the options bar and 2. create temporary / editable parametric labels.
Yes/No Formulas / Parameters |
Wed, Apr 23, 2008 at 8:57:16 AM
Autodesk SEEK alternatives? |
Mon, Apr 22, 2013 at 4:03:21 PM
Mystery parameters - shared? |
Tue, Nov 10, 2015 at 7:06:20 AM
wall lines - splines and ellipses |
Fri, Oct 12, 2007 at 1:03:05 PM
Titleblock Parameters [ 1 2 ] |
Thu, Mar 13, 2014 at 4:57:53 PM
17
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
