117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Custom Options bar parameter
Mon, Aug 17, 2009 at 4:11:38 PM | Custom Options bar parameter
jonelizares
I was just wondering if it was possible to make an instance parameter in a family to be editable through the options bar? for example: a box family with instance parameters for length and width. i would like to be able to input values for the two parameters via the options bar rather than having to go into the element propertes of the component. is this possible?
Mon, Aug 17, 2009 at 4:17:14 PM | Custom Options bar parameter
... getting tired today... No...
Edited on: Mon, Aug 17, 2009 at 4:25:19 PM
Mon, Aug 17, 2009 at 4:35:46 PM | Custom Options bar parameter
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I think you can accomplish this with a 'Tag' that has the 'labels' that contains the same linear parameter as the ones you want to change. Same general outcome as your 'options bar' approach without having to use the options bar to host the information.
Tag the object and drive the parameters from the tag itself.
Custom Type of Parameter in Family Editor
Thu, May 14, 2015 at 3:03:41 PM
REVIT MEP, Diffuser Airlfow Parameter isssue
Mon, Jun 21, 2010 at 1:46:23 PM
Creating custom millwork with reveals and counter tops. custom dining seating
Sun, Dec 19, 2010 at 8:43:00 AM
Large Monitors and Options Bar "Skipping"
Thu, Apr 23, 2009 at 3:22:07 AM
Option Bar in 2010
Tue, Dec 8, 2009 at 6:36:30 AM
Page generation time: 1.2766
