73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> Change the stringer of the stair
Mon, Aug 17, 2009 at 3:28:44 AM | Change the stringer of the stair
Hanh
Hi everyone
May you help me.
I designed a stair that has two stringers, but I want these stringers are by a round shape and the runs by glass.
I don't know how to change the stringer from rectangle to round.
Thank you for any help
Mon, Aug 17, 2009 at 5:30:06 AM | Change the stringer of the stair
4 Stars: 203 Votes
You can create that like a "Railing", draw that in the position you want, then in the properties you can change the offset, distance, the profile (in this case round), the material and so one...
Mon, Aug 17, 2009 at 5:49:42 AM | Change the stringer of the stair
Hanh
Thank you. You're a revit skill person
Mon, Aug 17, 2009 at 9:23:04 AM | Change the stringer of the stair
Hanh
Hi Typhoon
I followed what you showed me and created a stair like this (please look the picture)
Now I don't know how to add the support beams for the runs. Can you help me more
Thanks a lot
Mon, Aug 17, 2009 at 9:43:15 AM | Change the stringer of the stair
4 Stars: 203 Votes
"Now I don't know how to add the support beams for the runs." - Like what? show me what you want....
Tue, Aug 18, 2009 at 3:35:52 AM | Change the stringer of the stair
Hanh
There is the steel bars connect from two stringers to support the runs
Tue, Aug 18, 2009 at 3:55:08 AM | Change the stringer of the stair
Hanh
I just want to say about the treads and risers ... I' m sorry for my words.
Tue, Aug 18, 2009 at 7:52:39 AM | Change the stringer of the stair
Look at the "samples" in the on-line library.  There are sample stairs that have different configurations and stringers.  You can copy/clip those into your model and just change type.
Tue, Aug 18, 2009 at 8:35:40 AM | Change the stringer of the stair
Hanh
Thanks
Stair stringer offset (2015)
Mon, Sep 14, 2015 at 9:19:19 AM
Stair Stringer Cutting Stair Treads and Risers See Image
Thu, Jun 5, 2014 at 7:59:38 AM
Stringer in Stair by Run: Problem with offset
Tue, May 6, 2014 at 7:44:18 PM
PRECAST STAIR STRINGER
Mon, May 19, 2014 at 8:44:39 PM
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Page generation time: 3.3870
