Forums >> Revit Building >> Technical Support >> beam finishes
2 Posts No Rating |
hi, I have an isolate concrete beam in a midlle of a room and I want this beam with a 25 mm finish material in every beam side , how can I get this?? I´ve tried to enclose the beam with a wall (25mm large in all faces) changing the height of wall base level. Please, that's the best way to make this? Thanks.
I'm sorry but this question is not clear. Are you adding something like fire proofing?
2 Posts No Rating |
if u are not using revit str later, just create a wall family made of concrete.. simple as that
2 Posts No Rating |
Thanks Raniere.
2 Posts No Rating |
even, if you are going to use material schedules later, you will notice revit has a lot of miscalculations in what regards to joining structural beams into walls.... for instance just work as i said.. for columns and beams just create concrete walls (for beams inside walls use a sectional (stacked) wall.. kind of workful but precise if u gonna schedule..
Internal Wall Finishes |
Tue, Mar 25, 2014 at 4:18:18 PM
Meeting Beam Systems to Glulam Beam |
Wed, Jun 20, 2012 at 10:34:16 AM
floor finishes |
Thu, Jul 1, 2010 at 7:19:37 AM
Precast Beam System not sitting on beam |
Thu, Jan 10, 2013 at 11:45:48 AM
Creating a wall finishes schedule, and coding wall finishes on elevations |
Fri, Jun 1, 2012 at 4:06:32 PM
Members: | 2115733 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
