63 Users Online (62 Members):
Forums >> Revit Structure >> Technical Support >> Solid cutout from walls
is there a way to make some sort of void form that forms a cutout of a wall (other than wall->edit profile)? somehow attach a void form to a wall?
Did you try to create the "Void" in a family like "Generic Model Wall Based" or "Generic Model Face Based", for example??? You could explain better what really do you need/want...
that would work. I was trying to create a recess in a wall, not going all the way through.
No problem, you can still do what Ty said. Just constrain the void to a certain distance from the wall face so it doesn't go all the way through. 1"...2" 3" etc. Or even better, you could have a dimension / length parameter for 'recess depth' to control the depth.
frosted glass with image cutout |
Fri, Sep 23, 2016 at 4:51:32 AM
Changing Text Box Cutout |
Thu, Feb 14, 2013 at 11:06:48 AM
cutout in a concret wall |
Tue, Jan 29, 2008 at 11:21:10 AM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Render: Avoiding a hollow element when using "Cutout" |
Tue, Jun 9, 2015 at 2:00:10 PM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
