40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Detail Component Visiblity in Sections
Fri, Aug 14, 2009 at 12:29:10 PM | Detail Component Visiblity in Sections
kyoungblut
Ok, so i have a series of Detail Components that i want to add to my Family.  The thing with these is that for different Elevation Sections i want a different Detail to show up.  But Revit will not allow me to do so.
 I have inserted the Detail Components onto a specific Reference Plane (to orient them) and have selected "Show only if Instance is Cut" & de selected "Draw in Foreground" and yet it still shows the Detail Component in all of the 3 Sections i am trying to create.
 If anyone has a soluntion or anything PLEASE HELP!!!
Fri, Aug 14, 2009 at 12:53:24 PM | Detail Component Visiblity in Sections
tim123
4 Stars: 19 Votes
You need to switch off the actual component in the view, under visibilty / settings you can set the modeled component to not display.
Fri, Aug 14, 2009 at 3:35:29 PM | Detail Component Visiblity in Sections
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
How about creating new 'sub-categories' and putting the objects on those new sub-categories and manipulating the visibility that way?
Detail Components & Wall Sections
Fri, Mar 18, 2011 at 10:35:05 AM
Stone Detail Component???
Fri, May 31, 2013 at 3:56:20 PM
building sections visible but detail view sections NOT visible on all drawings??
Tue, May 27, 2008 at 12:50:21 PM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:16 PM
Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:30:54 PM
Page generation time: 17.2203
