Forums >> Revit Building >> Technical Support >> Can't select door/panels in storefront
Weirdest thing. I was going around changing storefront panels to doors, obscure panels, etc., then went to a 3D view to make sure it looked ok, and when I came back to do more, I couldn't select any panels. Tried tabbing through RIGHT OVER the panels...nothing. Then I noticed that the doors I put in elsewhere were showing up closed in plan. I'm stumped. Did I accidentally change a setting somewhere? I tried closing and re-opening, but I still can't select any door/panel in the storefronts. Help me!
Can you select other parts of the curtain wall? You're possibly in the wrong design option.
I can select the whole storefront...even the mullions. Just not the panels. I think the biggest clue is that the doors I replaced glass panels with are now showing up closed in plan. Never saw that before. I made sure my view depth settings were all ok, and they were. Still stumped.
Did you try to select by "Crossing" then go to the "Filter"?
Storefront Wall needs Storefront Doors |
Mon, Dec 3, 2007 at 8:58:53 AM
Problems with selecting mullion on curtain grid |
Wed, Jun 11, 2014 at 10:38:31 AM
Curtainwalls and Doors |
Wed, Sep 20, 2006 at 11:17:42 AM
Storefront door problem...please help! |
Mon, Aug 11, 2008 at 3:03:39 PM
Storefront Door Editing |
Fri, Jul 30, 2021 at 3:39:17 PM
Members: | 2098599 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
