37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Why do I get these huge trees?
Thu, Aug 13, 2009 at 9:47:00 AM | Why do I get these huge trees?
davedarch
Why do I get these huge trees when I import into 3ds max? there are like 4 layers of them on the top and bottom of my model!
Thanks,
-David
Thu, Aug 13, 2009 at 11:02:28 AM | Why do I get these huge trees?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
your units are probably incorrect. check Customize/Units Setup
I think mine is set to feet/ fractional inches
Thu, Aug 13, 2009 at 2:11:56 PM | Why do I get these huge trees?
davedarch
I don't think it's the units cause the whole building is importing correctly. Just these trees are HUGE!!! Hey Alabaster, how do you do your trees/people in your 3ds max renderings?
Thanks,
-David
Thu, Aug 13, 2009 at 2:52:54 PM | Why do I get these huge trees?
alabaster2513
3.5 Stars: 25 Votes
I usually photoshop them in. but if i do use landscape i'll usually use the Xfrog freebies on SEEK, try this link
http://seek.autodesk.com/search.htm#query=search%5Enew%5Equery%3Dxfrog%3Bsource%3DQuickLinks
I only use people if I'm told too, I think they look dumb in a render
Wed, Aug 19, 2009 at 1:18:12 PM | Why do I get these huge trees?
davedarch
Hey Alabaster, how do these trees work? are they placed in 3ds max? can they be imported into Revit?
-Thanks
Wed, Aug 19, 2009 at 2:02:36 PM | Why do I get these huge trees?
alabaster2513
3.5 Stars: 25 Votes
They are for use in Max directly, Revit cannot handle these types of complex models. I suggest you download a couple and open them in max and then research mental ray proxy objects, this will save you tons of time when rendering.
Edited on: Wed, Aug 19, 2009 at 2:03:00 PM
Fri, Aug 21, 2009 at 9:21:28 AM | Why do I get these huge trees?
Wolfmann16
there's no way to convert them for Revit?  Dang...cause they look pretty killer compared to some of Revit's stock stuff.  I thought it was possible to bring some things over from 3DS like cars...
Fri, Aug 21, 2009 at 10:55:06 AM | Why do I get these huge trees?
alabaster2513
3.5 Stars: 25 Votes
you can bring in cars and low poly trees, but most of these trees have a poly count to high for revit.
Fri, Aug 21, 2009 at 1:16:22 PM | Why do I get these huge trees?
davedarch
wow, finally figured out mental ray proxies and it looks like a life saver. Downloaded Zap's scrip and it works effortlessly.
Fri, Aug 21, 2009 at 1:16:58 PM | Why do I get these huge trees?
davedarch
Oh, here's a link to the script:
http://mentalraytips.blogspot.com/2008/04/3ds-max-2009-released-mr-proxies-and.html
Fri, Aug 21, 2009 at 2:23:50 PM | Why do I get these huge trees?
#11
davedarch
Hey Alabaster, do you know if it is possible to make a library of these proxies and use them in multiple scenes? How would I go about doing this? They don't seem to work properly when created from the original files...
Fri, Aug 21, 2009 at 3:35:31 PM | Why do I get these huge trees?
#12
alabaster2513
3.5 Stars: 25 Votes
You should be able to easily create a library, I will try and make a tutorial this weekend using that script.
Mon, Aug 24, 2009 at 9:50:28 AM | Why do I get these huge trees?
#13
davedarch
Hey Alabaster, did you get a chance to create that tutorial? or if not, could you quickly explain what to do? I've tried opening up the xfrog tree models and using the script to create the proxies but my trees keep coming out black and without materials. What could I have done wrong here? Also, After I've made the scripts, how to I add them to a scene?
I cleaned up the multiples...wwhub
Edited on: Mon, Aug 24, 2009 at 9:57:14 AM
Mon, Aug 24, 2009 at 10:45:16 AM | Why do I get these huge trees?
#14
alabaster2513
3.5 Stars: 25 Votes
I have not had a chance to use the script. You may need to use an xref material in order for your diffuse and opacity maps. they should render properly then
2D trees - Elevations
Wed, Oct 10, 2012 at 4:00:17 AM
Rendering Trees in Revit 2010
Wed, Apr 27, 2011 at 2:53:37 PM
Revit 2012 problem rendering RPC trees
Tue, Sep 6, 2011 at 5:26:07 AM
Rendering Trees
Mon, Mar 19, 2007 at 7:15:32 PM
Some trees not casting shadows
Thu, Oct 16, 2014 at 10:55:22 AM
Page generation time: 0.2290
