21 Users Online (20 Members):
Forums >> Community >> Newbies >> Why do I see the chairs that are under the table?
2 Posts No Rating |
Hello I´m a new person to the community and a newbie to Revit. Some tables that I use let the chairs under them be visible and some don´t. Obviously I would like the chairs under the table not be visible. I´ve checked the settings, the tabletop is higher than the chair, the visibility-settings are the same and I can´t spot differences in the element properties. The tables came with the Revit and/or came with the finnish localisation set.
2 Posts No Rating |
Problem solved. i noticed that after editing the table so that the tablotop was visible in plan view, only the symbolic lines of one particular chair-family remained visible through tables. I found a solution for this. I opened the chair -family for editing, in ref-plane i selected the lines and from element properties cleared the "draw in foreground." After this I had to change the visibility -settings of the family in 3d (made it visible in plan view - again). Result: the floor-color from room color-scheme doesn´t show through the table nor the chair. And neither is the chair visible through the table. Yes, I am invinsible!
table and chairs |
Thu, Apr 29, 2010 at 7:35:01 PM
grouped objects in legends |
Thu, Mar 12, 2009 at 2:26:45 PM
Embedded furniture tagging |
Thu, Jul 22, 2010 at 12:37:04 PM
Wrought Iron Table and Chairs Bistro Set |
Thu, Apr 3, 2008 at 8:30:15 AM
Import DWG in Family - Problem!!! |
Fri, Sep 28, 2007 at 2:31:36 PM
Members: | 2017971 | Objects: | 22948 | Forum Posts: | 152215 | Job Listings: | 3 |
