153 Users Online (152 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Rendering help... what is going on here???
Wed, Aug 12, 2009 at 4:04:47 PM | Rendering help... what is going on here???
davedarch
Hi, I've imported my Revit to 3ds max through .fbx. I am trying to render an interior scene but am getting wierd coloration or what looks like reflections. Does anyone know what's going on here? (see attachment)
Thanks,
-David
Wed, Aug 12, 2009 at 6:31:04 PM | Rendering help... what is going on here???
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
it looks like it may be coming from your light fixture, try hiding just the diffuser not the light object
Thu, Aug 13, 2009 at 9:10:21 AM | Rendering help... what is going on here???
davedarch
Hey Alabaster, thanks for your help as always! The lights I am using is a flat round light that I've changed the light source definition to a photometric hemi_ideal.ies. I then tried a recessed can light with a spot_ideal.ies definition. The can light got rid of all those lines. So your suggestion that it was the light cover was spot on. I can't use these recessed cans through because i need a light source that will fill the room with light and not just provide a spot light. Do you have any preferred IES definitions for the type of light I require? Also, how do i only hide the diffuser?
-David
Thu, Aug 13, 2009 at 10:05:31 AM | Rendering help... what is going on here???
davedarch
Another problem I have is that when i import the lights into 3ds max, the light rotates 90 degrees. So I have to set my lights to 90 degrees in revit to be 0 degrees and pointing down in 3ds max. what's up with that?
Thu, Aug 13, 2009 at 10:45:36 AM | Rendering help... what is going on here???
alabaster2513
3.5 Stars: 25 Votes
Its not so much your diffuser solid thats the problem, its probably the material assigned to it. try changing the material and see if that helps. as far as light rotation 90 degrees should be correct as Revit sees 0 degrees as being horizontal, in your Revit model you can go into Visibility/Graphics and under lighting fixtures turn on light source. you will now be able to see the photometric web file in your Revit scene.
Wed, Sep 9, 2009 at 2:03:15 PM | Rendering help... what is going on here???
davedarch
Hey Alabaster, what lights do you usually use when you're going from revit to max?
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
help with rendering!
Wed, Aug 10, 2016 at 10:47:17 PM
Page generation time: 2.3673
