Forums >> Revit Building >> Technical Support >> Floor - Furniture
7 Posts No Rating |
Hi, I have a project in which i inserted floors, and as soon as i started inserting Plumbing fixtures/furniture, the floor is still appearing through the furniture/appliances... i have already checked the properties to see if furniture/appliances were marked as transparent, but they aren' t... This is my second Revit project and i didnt have this problem on my first one, so if you can help me figuring it out what could me the configuration i would need to check, it would help me very much!
Is your view set to wireframe?
7 Posts No Rating |
NO, ITS HIDDEN LINE...
How about posting a plan view, screen capture image. Could be 'view range' related'. What's your view range settings at? Upload screen capture. So I think what you are saying is the 'surface pattern' of the 'floor material' is showing through the furniture. The floor (edges) are probably NOT showing through. I assume you're using 'stock' plumbing fixtures so they are most likely ok. I would verify their elevation. I would also investigate the fill pattern used as the surface pattern for the floor material. Try changing it.
Edited on: Sat, Aug 22, 2009 at 10:42:42 PM
Furniture and overlays |
Tue, Sep 24, 2013 at 8:48:23 PM
Furniture Visibility |
Mon, May 21, 2012 at 11:33:48 AM
Furniture Tags & Sketchup Furniture Components |
Fri, Dec 4, 2015 at 9:35:33 PM
Objects on floor above showing |
Fri, Nov 13, 2020 at 4:19:52 AM
Furniture, Doors, Casework, In Place Components have x-ray, see through properti |
Wed, Jan 25, 2012 at 4:07:10 PM
Members: | 2115152 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
