74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Merging toposurfaces
Wed, Aug 12, 2009 at 10:08:34 AM | Merging toposurfaces
beckyl
Revit 2010.
 I am trying to place a building pad on a toposurface. The problem is that I had to split the toposurface into three parts - this is because there is an excavated area at a much lower elevation. When i try to merge the surfaces, it oversimplifies them. How do I deal with this? File is attached.
THanks!
Wed, Aug 12, 2009 at 12:50:54 PM | Merging toposurfaces
4 Stars: 203 Votes
Why you don't just create a PAD rather than create 3 surfaces?
Wed, Aug 12, 2009 at 1:03:36 PM | Merging toposurfaces
beckyl
 The problem is that I need to describe the existing condition -this is previously excavated. I need to draw the existing building pad on TOP of this, the existing topography, to figure out the volume that still needs to be excavated.
(thanks though!)
Wed, Aug 12, 2009 at 1:36:09 PM | Merging toposurfaces
I don't understand the three parts.  I would have thought that your existing topo is one topography and shows the previously excavated area.  If it did not show it correctly because of inadequate points, you could have added those manually like Typhoon did to get his vertical topo area then just use a pad for your new pad location.
Wed, Aug 12, 2009 at 3:44:37 PM | Merging toposurfaces
beckyl
Is the problem likely that i don't have enough points? I tried adding more points surrounding the edges and that seemed to work to join 2/3 parts. Now I'm getting the problem where when I merge the remaining two surfaces - they disappear.
If anyone could help me out with this I would really appreciate it. Thanks.
Merging Toposurfaces
Tue, Apr 21, 2015 at 8:07:54 AM
Can you tell a building pad to cut multiple toposurfaces? Revit 2014
Tue, Aug 12, 2014 at 2:45:17 AM
Merging Shared Parameters
Mon, Jun 8, 2009 at 3:08:13 PM
Beam not merging
Mon, Mar 16, 2009 at 5:57:10 AM
topo depth
Wed, Nov 7, 2012 at 1:01:24 PM
Page generation time: 1.6393
