81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Unintended Consequence
Mon, Aug 10, 2009 at 11:00:45 PM | Unintended Consequence
renais
I started making a window family on my own starting with a toilet-high type and how it appears when inserted is weird than what I expect.
I guess it's because of the clipping or view range. I tried raising up the clipping level and there was a slight improvement viz. - the cutting edges of the wall opening appeared but that's just about it, before it looked like a vessel floating on a canal.
But still. the window remains a rectangular floating object above the cut portion of the wall. It definitely represents the uncut header of the window frame.
There's not much I can think of to show that the cutting should be on the frames and the glass.
64210_Window_Intention.tif64210_Window_Result.tif
Wed, Aug 12, 2009 at 11:55:08 AM | Unintended Consequence
violet78
violet78 Avatar
Try setting the visibility of the header so that it doesn't show in plan views.
Wed, Aug 12, 2009 at 12:09:15 PM | Unintended Consequence
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
considering that adjusting the view range helped, you might try a plan region with different view range settings.
Title View - Unintended Text Wrapping
Tue, May 12, 2020 at 9:49:00 AM
NEW Gyp on EXISTING Stud wall
Mon, Mar 5, 2007 at 8:59:02 AM
Dimension String
Tue, Aug 29, 2006 at 5:55:24 PM
difference between two options of callout
Thu, Mar 24, 2011 at 10:08:40 AM
Tag moves to another location after reload og family
Wed, Jun 17, 2015 at 5:56:44 AM
Page generation time: 0.1780
