71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Existing Stairs
Sun, Aug 9, 2009 at 9:06:08 PM | Existing Stairs
rgaaia
using 2010:
i am rnovating an old house and am putting the as builts conditions in.....i can't seem to make the stair tool work to draw the existing stair...which has a rise and run that is steeper than the rules allow any help??????
R..
Mon, Aug 10, 2009 at 1:36:54 AM | Existing Stairs
tim123
4 Stars: 19 Votes
You can change the rules.  Go into the stair properties before you draw the stair and set the minimum tread depth and maximum riser height to suit.
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:47 PM
existing stairs not showing up as dashed in existing mode
Wed, Dec 20, 2006 at 1:55:38 AM
Using in place models to create an existing concrete stairs
Wed, Sep 24, 2014 at 7:14:41 AM
Stair questions... Revit 2010
Wed, Jul 13, 2011 at 12:23:40 PM
stairs wont demo off my plan
Wed, Aug 13, 2014 at 3:16:06 PM
Page generation time: 2.5399
