72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> building Pad
5 Posts No Rating |
If building pad is used a basement floor, the pad is set inside of foundation walls. What do you do with topo sharing same space as foundation wall? look at jpg where foundation wall ends and generic wall above attaches.
Looks like you need to edit that pad sketch and move it into the wall.
5 Posts No Rating |
I could definitely move the sketch of the pad out, thought of that, I would then be showing the foundation wall on top of the slab which isn't standard practice. I can hide pad in view and insert concrete floor using floor command, just an extra step.
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Use one pad to form the excavation (ie: using 'pick walls' method) and then turn off it's visibility and one pad for the basement slab.
Edited on: Sat, Aug 8, 2009 at 9:16:48 AM
5 Posts No Rating |
THAT'S WHAT I THOUGHT, JUST THOUGHT I MIGHT BE MISSING SOMETHING. THANKS-
Building Pad Problem |
Thu, Dec 20, 2012 at 3:51:08 PM
Building Pad Altering My Topography Surface |
Wed, Nov 30, 2011 at 12:01:59 PM
Building Pad and Ecotect |
Wed, Feb 2, 2011 at 11:12:06 AM
building pad |
Wed, Dec 2, 2009 at 8:34:09 AM
Building pad, what is it exactly? |
Mon, Dec 20, 2010 at 11:51:40 AM
14
Members: | 2022524 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
