Forums >> Revit Building >> Technical Support >> Revit 2010 family parameters formula and room tag
69 Posts No Rating |
hey folks, i tried to find this question on a search, but to no avail. I want to edit a room tag so that it will calculate the occupancy load and display it on the tag. i have tried severl avenues but withouot success. i susoect that is has to do with creating a label that will calculate the formula. any suggestions? thanks for your help.
You can 't do this. Sorry labels read data from parameters that belong to elements.
Edited on: Fri, Aug 7, 2009 at 2:29:14 PM
WWHub, thanks for your response. a room is an element correct? I am trying to use the square footage of the room to calculate the maximum occupancy of a room automatically. i believed that using a room tag would be able to perform this calc. perhaps it can be done in the room itself?
You must not have searched this forum using occupanct as your sort because there are numerous threads. Look at this one: http://www.revitcity.com/forums.php?action=viewthread&thread_id=8766
I see, thanks again. Now, is here a way tot information to my plan?
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
ROOM TAG AREA FORMULA |
Thu, Sep 3, 2015 at 6:22:18 PM
Adding Room Tag Parameters |
Tue, Oct 24, 2006 at 10:29:46 AM
Drop down list for room tag , and add the parameter to project parameters |
Thu, Jan 6, 2011 at 2:59:01 AM
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
Members: | 2102383 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
