32 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Doors displaying as gray in Shading with Edges
Thu, Aug 6, 2009 at 1:36:06 PM | Doors displaying as gray in Shading with Edges
rktekt04
I am working on getting material and color assignments correct in Revit for a model so it will render correctly, have accurate colors in a shading with edges view for quick client requests, and display correctly on sheets in black and white for construction documents.  However, the doors (all types, sizes, families) are displaying as solid gray with no edges (see attached picture).  I've assigned materials, changed setting both in the families and in the model, but they only display as gray.  Anyone know why this is and how to make it stop?
Thu, Aug 6, 2009 at 2:25:25 PM | Doors displaying as gray in Shading with Edges
tim123
4 Stars: 19 Votes
In the material settings you need to go to the Render Appearance settings and set it the way that you want it to appear (assuming 2009 or 2010).  If you've done that then it may be to do that the doors are in a different phase.
Thu, Aug 6, 2009 at 3:46:43 PM | Doors displaying as gray in Shading with Edges
rktekt04
I set all that up because as the default in Revit, the doors were coming up orange and the frames a dark gray.  I figured out setting that up in the family and then reloading it into the model doesn't matter as you have to set the rendering appearance in the model as this drives the building appearance.  The part I thought was odd is that the edges aren't defined like the adjacent components; the doors dont' have a defining edge line.
Why do walls turn gray in renderings? color shows in shading w edges...
Thu, Apr 23, 2009 at 10:26:03 PM
shading with edges problem
Wed, Nov 17, 2010 at 6:49:50 AM
Doors make a gray shadow in Sections
Wed, Apr 7, 2004 at 10:39:44 AM
TOO DARK Shading with Edges Revit 2009
Mon, Aug 25, 2008 at 6:57:20 PM
11
Shading w/ Edges Color Differences
Thu, Jul 23, 2009 at 2:18:44 PM
Page generation time: 0.9569
