99 Users Online (98 Members):
Forums >> General Discussion >> Revit Project Management >> Improving performance of Revit projects
Have you guys already see this: http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=13126294&linkID=9243099
thanks Typhoon, just thought i would post it. Issue You want to know how to minimize the size of your Revit® files in order to optimize project performance. Solution Here are some general tips and tricks that will help you to keep the size and performance of your Revit files under control: - Break up a large model into multiple files and link the files together if you are experiencing performance issues. This will work best if you can work on one file while the other links are unloaded most of the time.
- Purge unused objects. (Note: Purged objects cannot be recovered, so please make a backup of your project before purging.)
- Remove any unused design options. Even though options may not be active or visible, when changes are made within the main model, all design options have to be updated.
- Remove unwanted raster images or renderings, as they can quickly increase file size.
- Do not import a very large raster image and then scale it down to fit the title block. It will retain its original file size.
- Black and white raster images are smaller than color raster images. Save black and white raster images in 1-bit per pixel format instead of JPG. (In Microsoft Paint, this format is called Monochrome Bitmap.)
- Remove unused groups. Delete them from the Project Browser if they exist instead of using the Purge command.
- Create a new, blank drafting view to be used for opening and closing the project. Before saving and closing, open this view and close any other open views. This will prevent unused views from being loaded during startup, freeing up RAM memory and increasing speed.
- Regularly review and fix warnings (click Tools menu > Review Warnings).
- Reduce unwanted data.
Edited on: Fri, Aug 7, 2009 at 1:37:45 AM
curious about size (s.f.) of revit projects? |
Thu, Nov 17, 2005 at 11:22:07 AM
Revit Project Performance |
Tue, Jul 12, 2011 at 2:18:44 PM
Slow Model? – How to Increase Revit Performance |
Thu, May 23, 2013 at 2:22:22 PM
Worksets |
Fri, Apr 14, 2006 at 3:07:09 PM
Posted Performance of Currently used/tested Revit Systems |
Wed, Apr 21, 2010 at 9:35:29 AM
12
Members: | 2026419 | Objects: | 22993 | Forum Posts: | 152211 | Job Listings: | 3 |
