72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Level Marker Alignment in Linked Elevations
24 Posts No Rating |
Hi there, I'm working on a large multi-building project with separate buildings referenced into a central file for sheet setup purposes. Most things are working OK, but have a small problem with level markers. It seems that they do not update into the central assembly file after being modified in the building model file (bubble position, offset etc). This is despite closing/reopening the assembly file and reloading the linked building files. The elevation views in the central assembly file have VG settings according to the linked building elevation view, so it's not that. Effectively the VG settings are good, it's just this alignment updating that doesn't seem to work. Cheers
Level Marks??? |
Wed, Apr 8, 2015 at 2:06:31 PM
Elevation Level Marker Associated To Wrong Floor Plan |
Wed, Feb 25, 2015 at 10:44:23 AM
Problems with linked files and interior elevations |
Wed, Aug 3, 2011 at 7:59:52 AM
First Floor Level Marker Disappeared |
Tue, May 19, 2015 at 10:56:23 AM
Dual units on level markers |
Fri, Nov 14, 2008 at 9:31:23 AM
Members: | 2057641 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
