Forums >> Revit Systems >> Technical Support >> shared parameter causes revit crash - journal error included, please help.
Every time I try to load my family into any of our existing projects revit crashes. It loads into new projects just fine. the journal error is as follows: 0.169317 1:<<MFCDoc::OnOpenDocument [S:\Revit MEP 2010\Imperial Library\HA Content\HVAC\Heat pumps\HEAT PUMP CLIMATE MASTER LEFT RETURN.RFA] ' 1:--Post event status Succeeded ' 1:--API application event DocumentOpened returned status DidNotRaise ' 0:< DBG_WARN: Mismatched external parameter definitions! GUID='ffc21ae8-b4a4-438c-9e61-e06d8a01a40c' Existing parameter: Name='PRESSURE DROP' ParamType='15', '-1', '39' New parameter: Name='PRESSURE DROP WATERSIDE' ParamType='15', '-1', '39': line 682 of .\Elem\FamilyUI.cpp. 'C 06-Aug-2009 10:14:29.467; 0:< Assertion failed: line 688 of .\Elem\FamilyUI.cpp ' 0:< Exception occurred then it goes into the routine crash info. I have deleted my parameter called "pressure drop waterside from both the family, and the shared parameter file.... no change, same error.
Are trying to load a family that was created in 2010 into a project that was originally created in 2009 (or earlier) but upgraded to 2010?
no, these files were all created and inserted into a 2010 format. Interestingly enough, this error has occured again in a new part. the only common denominator in both files was a shared parameter entitled "pressure drop waterside" when I recreated the part without that parameter, it inserted correctly. I could not just delete the parameter and re-insert. Im running with it as-is, and not using "pressure drop waterside". I would however like to know what if anything can corrupt a shared parameter (but the the whole shared parameter file), and how to prevent this from happening again in the future.
Shared Material Between Families |
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Shared Parameters- Error Message |
Fri, Jun 19, 2009 at 1:31:30 PM
Revit 2012 - Try to recover rvt file from Journal Files |
Mon, Jun 25, 2012 at 12:16:27 PM
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:48 PM
Members: | 2116613 | Objects: | 23196 | Forum Posts: | 152298 | Job Listings: | 3 |
