32 Users Online (31 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:28:30 AM | Monolithic Stair with Stringer
ririe44
Hey all!
I'm trying to build a concrete monolithic stair that has a steel tube stringer on one side (for guardrail attachment).  All my stringer options are gone with the monolithic stair... is it possible?
Wed, Aug 5, 2009 at 10:43:25 AM | Monolithic Stair with Stringer
Monolithic... means mono (one) material.  If you want a stringer, then don't use the mono stairs!  Why do't you add the tube as part of your railing... just the bottom rail?
Stair Stringer Cutting Stair Treads and Risers See Image
Thu, Jun 5, 2014 at 7:59:39 AM
Monolithic stair - large construction height error
Thu, Oct 13, 2011 at 12:10:34 PM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:19 AM
13
Stair Stringer Question
Fri, Jul 28, 2017 at 4:01:09 PM
Curved monolithic stair problem
Thu, Mar 11, 2010 at 2:33:32 PM
Page generation time: 0.3322
