39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> rendering horizontal wood siding.
Wed, Aug 5, 2009 at 10:21:53 AM | rendering horizontal wood siding.
joegaughan
I am missing something which is most likely very easy to solve.  I want to show an exterior horizontal wood (hardiboard) siding in my rendering.  I have the materials set up and wall created with wood, but can't figure out how to show any lap siding in the rendering.  Am I overlooking a material that has this built in, or do I have to create a special horizontal scoring to show the affect.  Any advice would be greatly appreciated.
thanks,
Wed, Aug 5, 2009 at 10:40:06 AM | rendering horizontal wood siding.
You have to use the material you want.  For lap siding you need a material that uses a bump to achieve the 3D effect of the lap siding.  I do not believ there is a stock lap siding in the library.  You can look at the shingled materials tgo see how the seperate bump file is used.  You will have to get a lap siding jpeg and you can make a bump file form that.  There are discussions of this process elsewhere.
Wed, Aug 5, 2009 at 10:49:01 AM | rendering horizontal wood siding.
joegaughan
The roofing tip helps a lot.  I will create the jpeg in a white or grey, and then apply a color to in revit for the accents.  Hope this works.  Thanks a bunch.
revit 2015-exterior elevations horizontal lines of wood siding
Sun, Dec 6, 2015 at 10:01:17 PM
Showing Horizontal Lap Siding correctly in Rendering
Mon, Jan 23, 2023 at 2:41:30 PM
Wood Siding
Fri, Nov 22, 2019 at 3:17:59 PM
11
Timber cladding (hit or miss style) in revit architecture 2012
Tue, Nov 6, 2012 at 9:09:00 AM
Wood siding
Wed, May 1, 2013 at 12:13:59 PM
Page generation time: 2.1311
