66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit to Navisworks - No exporter in 2010
Wed, Aug 5, 2009 at 7:04:26 AM | Revit to Navisworks - No exporter in 2010
Rams
3 Stars: 3 Votes
Now on the implementation stage....
Thu, Aug 6, 2009 at 9:04:12 PM | Revit to Navisworks - No exporter in 2010
TomDorner
4.5 Stars: 25 Votes
It does exist!
I believe it is on the subscribtion site.  Check with your re-seller if you can't find it.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:01 PM
2016 export Revit files to Navisworks without using Navisworks Exporter.
Thu, Apr 21, 2016 at 4:53:16 PM
When you attempt to use the Navisworks exporter in Revit, a “localization” error
Fri, May 18, 2012 at 6:54:00 AM
In Revit, the Navisworks File Exporter is grayed out on the ribbon menu
Fri, Jun 4, 2010 at 12:42:23 PM
Revit 2010 and Navisworks 2010
Mon, Mar 1, 2010 at 8:15:36 AM
Page generation time: 4.4383
