Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 8.4.09: +++ [RAWR I'M THE REF PLANE] —
Tue, Aug 4, 2009 at 8:59:19 AM | Revit TotD – 8.4.09: +++ [RAWR I'M THE REF PLANE] —
rkitect
rkitect Avatar
4 Stars: 29 Votes
If you don’t get the title of the tip, that’s OK.  It’s easier just to say that it’s hard to explain if you don’t already understand, but at the same time it’s not necessarily a bad thing if you don’t.  Either way, I’m guessing that there’s a little tip that you didn’t know.  The one that tells you which side of a reference plane that extrusion is going to actually extrude from.  Ever heard of it?  No!?  Well here goes.  This is, in my humble opinion, another short but AWESOME little tip!
The +’s and -’s of Reference Planes:
When you draw a reference plane left to right on your canvas, the positive side of the plane is ABOVE the ref plane and the negative side of the reference plane is BELOW the reference plane.  How is this helpful?
If you create an extrusion (for instance) on this reference plane that you just created, you know now which way the extrusion is going to go if you assign an extrusion start of 0 and end of 5'.  Anypositive part of the extrusion will be ABOVE this reference plane and anynegative part of the extrusion will be BELOW the reference plane.  Now you don't have to guess which way the Extrusion is going to go and you can make sure that you don't have to use negative calculations in yourformulas to control certain extrusions now.  So from now on, you'll be paying a bit more attention to how you draw your reference planes, eh!?
So there you have it; short, sweet and yet another incredibly powerful arsenal to your bag of tools.  Hope you enjoyed and hope to see you again for another, Revit TotD!
As always, you can view this tips in all of itsvideo and image glory at: http://revittotd.com/08/682
-Carl
revit_arch_09_cert_pro_rgb
Ref. Plane Constraints
Mon, Jan 23, 2006 at 1:08:16 PM
Revit TotD – 7.16.09: Is Reference Is Useful (ref plane parameters)
Thu, Jul 16, 2009 at 12:01:02 PM
Revit Arch 2009: Cannot align circular solid extrusion to ref plane
Thu, Aug 25, 2011 at 3:03:35 PM
question with ref plane
Wed, Mar 9, 2005 at 3:23:45 AM
Locking a Inseted Family To a Ref Plane
Tue, Jun 10, 2008 at 3:12:07 PM
Page generation time: 2.1617
