114 Users Online (113 Members):
Forums >> Revit Systems >> Technical Support >> Revit file export to autocad?
2 Posts No Rating |
Hello I working in revit architectural, but sometime the client need convert the revit file to dwg format. It's possible? I try when the drawing views or section , not pages, saved in dwg forma. But when I opened in autocad the drawing is une layer,without property layers, lines, etc. If any other process or exist to convert the rvt or rfa file to dwg? Thanks
I think you should read the HELP menu, try export to CAD files, you have the option to change the units, the layers, the color and so one, Read the HELP first.
export to autocad |
Wed, Jul 6, 2005 at 7:41:50 PM
Export to AutoCAD issues |
Fri, Jan 12, 2007 at 2:32:45 PM
exporting revit file to Autocad and layers are not correct |
Fri, May 22, 2020 at 9:53:49 PM
3d view export to AUTOCAD |
Thu, May 28, 2009 at 12:00:59 PM
Revit Export to AutoCad text issue |
Thu, Dec 16, 2010 at 1:38:19 PM
Members: | 2042307 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
