116 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Whats the difference between rough width/height and width/height??
Thu, Jul 30, 2009 at 8:14:43 PM | Whats the difference between rough width/height and width/height??
rudyard
1 Stars: 1 Votes
When creating doors/windows whats the difference between rough width/height and width/height??
Fri, Jul 31, 2009 at 6:53:10 AM | Whats the difference between rough width/height and width/height??
That all depends on how the family assigns them.  The rough dimensions may be model parameters or just number parameters for schedules.  The stock template does not assign these but they are setup as a standard parameter for consistency.  The width/height are used as model parameters and are assigned as labels in the template.
Edited on: Fri, Jul 31, 2009 at 6:54:18 AM
Mon, Aug 3, 2009 at 7:16:56 PM | Whats the difference between rough width/height and width/height??
rudyard
1 Stars: 1 Votes
Thanks, so the rough height and width can be made anything essentially when a family is created?
I had thought maybe one might be frame size and the other opening size or something but it seems it can mean whatever the creator wishes.
Thanks for the reply.
Whats the difference between Width and Rough Width
Tue, Aug 3, 2010 at 2:44:56 PM
Rough width and height - changing name
Tue, Aug 24, 2010 at 3:20:34 PM
Rough Openings Door/Walls
Wed, Mar 14, 2007 at 10:47:25 AM
Door Schedules
Mon, Aug 15, 2005 at 6:07:18 PM
type mark tags and height/width reference
Mon, Apr 13, 2015 at 10:04:43 AM
Page generation time: 0.3989
