75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Shipping containers - shop drawing set with multiple identical 3D views
Thu, Jul 30, 2009 at 6:40:17 PM | Shipping containers - shop drawing set with multiple identical 3D views
Stackdb
Hi All,
We run Revit 2009 currently. This issue is related to a set of shop drawings for a project we are building using shipping containers. I will have an identical set of views - including 3D Iso views - for 35 separate shipping containers and the modifications we are making to each one.
Can anyone advise on how to set up sheet/view templates such that I can easily ensure that each of the drawing sheets or portions of drawing sheet that deal with a particular container has the same exact views as all the others? The idea would be to do this within one model, as opposed to 35 separate revit files. Should I be positioning cameras with reference lines off of each container to keep it consistent?
Thanks everyone - I did search to see if I could find help on this in previous posts.
Andy - StackDB
Fri, Jul 31, 2009 at 6:46:42 AM | Shipping containers - shop drawing set with multiple identical 3D views
The elevation/plan/section views should be easy because you can align those.  The 3D view may be a little tougher but once placed, you can verify their properties are the same for height of camera and target.
You could have 35 design options....ouch... I don't like that ... you would need 35 duplicate views to place on sheets.
Why don't you want 35 models?  This is really the easiest way.
Fri, Jul 31, 2009 at 7:18:05 AM | Shipping containers - shop drawing set with multiple identical 3D views
Stackdb
WWhub -
You are definietly right. I'm going to go with separate models get them perfectly set up then just change the family type to the new container (each container is a type). This will also help with labeling of the sheets etc. Work smart not hard.
The only thing that remains to be overcome is that we are scheduling all the openings with a dedicated schedule for each container. I would then like to have a master schedule with all openings in the set. Is there any better way to do this then to just take all 35 separate completed container models, drop them into one sheet and run the custom schedule?
Thanks again - hugely helpful,
StackDB
Fri, Jul 31, 2009 at 7:19:01 AM | Shipping containers - shop drawing set with multiple identical 3D views
Stackdb
 - I meant drop them into one Revit file, not sheet - sorry.
Shipping Container Architecture
Tue, Apr 12, 2011 at 7:16:42 AM
shipping container project best way to do it
Mon, Apr 22, 2013 at 4:48:51 AM
rendering patterns
Sun, Apr 25, 2010 at 5:01:10 AM
Multiple Buildings - 1 Drawing Set
Wed, Jun 4, 2008 at 1:46:06 PM
Precast Concrete Shop Drawings
Fri, Apr 10, 2020 at 2:08:55 AM
Page generation time: 0.7890
