49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.30.09: Revit 2010 Add-In Manager
Thu, Jul 30, 2009 at 7:08:15 AM | Revit TotD – 7.30.09: Revit 2010 Add-In Manager
rkitect
rkitect Avatar
4 Stars: 29 Votes
Another short and sweet tip, this one dealing with an easy way to manager your add-ins.  If you are an add-in hog, you may get tired of editing your Revit.ini file every time you load and unload an add-in for Revit.  Well, with this simple little tool, you can have all the work done for you from inside Revit!
Downloading and Installing the Revit 2010 Add-In Manager:
  1. Browse to http://autodesk.com/ and search for “Revit SDK
  2. The first link should be a link to the developer’s center. Follow that link.
  3. Near the bottom of the bage there is a link to the Revit 2010 SDK.  Download and install that file.
  4. In the install directory, there is a directory called “Add-In Manager” containing a .MSI file, install that.
  5. You should now have the Revit 2010 Add-In Manager available from the Add-Ins menu in your ribbon.  You will need to have a project open to access the tool.
Using the Revit 2010 Add-In Manager:
  1. With a project open, go to Add-Ins > External Tools > Add-In Manager for Revit 2010.
  2. To load a new add-in:
    1. Click Load
    2. Browse to the location of the Add-In’s .DLL file.
    3. Select the DLL
    4. Click OK
    5. Click Save
  3. To Unload an Add-In:
    1. Select the Command or Application you wish to Unload.
    2. Click Unload
    3. Click Save
Both methods will require you to restart revit before the changes take effect, but at least you don’t have to edit the Revit.ini file! Thanks for stopping by again and I hope to see you next time for another Revit TotD!
As always, you can view this tip in its entirety at: http://revittotd.com/07/607
-Carl
Revit TotD - 8.26.2010 | Quick Plan Perspectives (via View Cube context menu)
Thu, May 31, 2012 at 3:02:55 PM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:47 AM
Revit TotD - 2.17.10 | Linked Model Visibility, part2
Wed, Feb 17, 2010 at 9:22:45 AM
Revit TotD - 8.30.2010 | Controlling your Demolition In-Fill Types
Mon, Aug 30, 2010 at 8:47:59 AM
Revit TotD – 2.24.10 | Render Texture Alignment
Wed, Feb 24, 2010 at 9:10:31 AM
Page generation time: 2.1956
