71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Beams & Things
Thu, Aug 4, 2005 at 4:22:06 AM | Beams & Things
Audrie
Hello me again - the Revit newbie. I am trying to place beams around the perimeter of my walls. That is okay I can do that, however I want to mitre them, and there seems to be no way to do it. Help aint much help. Anyone know how to deal with this? Thanks Audrie
Fri, Aug 5, 2005 at 11:46:12 PM | RE: Beams & Things
eldados
eldados Avatar
4.5 Stars: 8 Votes
I find working with beams to be a bit annoying at times... why don't you create a profile for your beam and just use sweep to go around the building?
Sat, Aug 6, 2005 at 10:27:53 AM | RE: Beams & Things
bolandereric
Beams are hard to work with I asked this question to a revit tech person when I was trying to myter a couple of steel beams together. He said you will have to go and create an in place family. Go to your Modelling tab and click on create and then you can create it right their in the drawing.
Mon, Aug 8, 2005 at 2:27:28 AM | RE: Beams & Things
Audrie
I am finding the Revit Help, unlike Autocad, quite inadequate for the newbie in telling you where to go to do things, and how to do them. I have downloaded everything written on 'sweeps 'and nothing appears to be what it seems... It is not clear how to access the initial commands. It seems to me beams should either be included on the Design bart/host sweep / command, or that the beams themselves should have a joining/mitreing option. Perhaps some experienced could come on chat and talk to me about it if they have time.. I am keeping it open during the day.
Mon, Aug 8, 2005 at 2:37:32 AM | RE: Beams & Things
eldados
eldados Avatar
4.5 Stars: 8 Votes
the sweep has nothing to do with the structural beams, this just a work around. first create the profile of your beam: file-new-family-metric profile. save and load to your project. under the "Modelling" tab choose "create..." make it a structural framing type, the tabs will change on the left, pick: "solid form-solid sweep" draw your 2D path in the plan where you want it toi go and for the profile use the one you created earlier... good luck Smile
Mon, Aug 8, 2005 at 5:49:39 AM | RE: Beams & Things
Audrie
Thanks very much for your clear concise reply, El. You must be working in Revit 7 because the commands you talk about dont appear to be there. Ihave the PFC loaded that I want to wrap around the perimeter already so that is no problem. I can go into STRUCTURAL and BEAM - but there appears to be no - solid form, nor solid sweep. Under MODELLING there is HOST SWEEP, and it opens up into wall, roof, floor. I understand from HELP that I could possibly pull the PFC into there and then sweep it around the building, but I cannot see any way to link it there.
Mon, Aug 8, 2005 at 5:50:27 AM | RE: Beams & Things
Audrie
Ah, I should add that I am using Revit 8
Mon, Aug 8, 2005 at 5:59:47 AM | RE: Beams & Things
eldados
eldados Avatar
4.5 Stars: 8 Votes
mate, under the modelling tab on the left the bottom one says :"create..." click and follow Smile been there since forever Smile
Tue, Aug 9, 2005 at 12:38:07 AM | RE: Beams & Things
Audrie
Thanks for the help - I was looking at the design tabs, not the dropdown menus - and of course there it was. While you put it very simply, and on the whole it was easy to do, there were still problems. When I had finished the sweep it only offerred me a choice of gutters and handrails that I could use, and I didn't see where I could pick up my imported beam. I hit the LOAD PROFILES button and pulled in a steel beam, but it merely told me that that was from the wrong category and wouldn't do it. Meanwhile I can see my original beam famil y in the project browser, but there seems to be no way to select it.
Tue, Aug 9, 2005 at 12:44:44 AM | RE: Beams & Things
eldados
eldados Avatar
4.5 Stars: 8 Votes
Audrie, you will need to sketch the profile yourself in a new profile family, and upload to your project...
SHOW PRIMARY & SECONDARY BEAMS WITH DIFFERENT LINEWEIGHTS ON A SECTION
Fri, Nov 12, 2010 at 7:07:47 AM
Beams
Tue, Nov 15, 2005 at 3:41:26 PM
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:50 PM
connections between beams & columns
Tue, Apr 8, 2008 at 12:11:49 AM
BEAMS & DIM. LUMBER
Thu, Aug 3, 2006 at 2:24:58 PM
Page generation time: 1.2186
