54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Intersection of two Barrel Vaulted Ceilings Cleanup
Wed, Jul 29, 2009 at 10:07:06 AM | Intersection of two Barrel Vaulted Ceilings Cleanup
nichitect
Revit Architecture 2009
I have two barrel vaulted ceilings intersecting at right angles.  To create these barrel vaults I made an in-place family for the ceiling that includes the solid and void extrusions for both barrels.  I then cut the voids out of the respective solids and it seems to create the proper geometry.  However in RCP there are way too many lines showing up.
 How can I clean up the intersection?
 I've tried experimenting, it seems the ceiling will cleanup if the vaults are the same width, but once one is a different size, they do not clean up.
Wed, Jul 29, 2009 at 10:11:14 AM | Intersection of two Barrel Vaulted Ceilings Cleanup
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Nice roof.
How about using the 'linework' tools and just make the unwanted lines 'invisible'. This is a view specific solution and can be done in any view.
Edited on: Wed, Jul 29, 2009 at 10:11:37 AM
Wed, Jul 29, 2009 at 10:25:39 AM | Intersection of two Barrel Vaulted Ceilings Cleanup
nichitect
Thanks, that's definitly better than masking and using detail lines.
Now, here's another twist, the ceiling is a going to be a linear wood panel grill system simular to this from Rulon:
http://www.rulonco.com/products/panelgrilles.aspx
So to represent this, we are using a line hatch, unfortunately at this intersection, things don't look so good, any ideas?
Wed, Jul 29, 2009 at 10:45:04 AM | Intersection of two Barrel Vaulted Ceilings Cleanup
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You could just use detail lines instead of fill patterns?
Wed, Jul 29, 2009 at 12:26:51 PM | Intersection of two Barrel Vaulted Ceilings Cleanup
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
perhaps a transparent filled region?
Barrel Vaulted Cellar
Fri, Mar 12, 2010 at 12:12:03 PM
barrel vaulted ceilings?
Tue, Aug 26, 2008 at 10:36:28 AM
Adding PITCH to a Curved/Barrel-Vaulted Roof
Thu, Feb 21, 2008 at 8:21:25 PM
Trey and Vaulted Ceilings
Wed, May 26, 2010 at 6:00:27 AM
Creating vaulted ceilings
Tue, Sep 26, 2006 at 12:52:55 PM
Page generation time: 0.2597
