100 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Starting Order for Room Tags
Wed, Jul 29, 2009 at 8:27:47 AM | Starting Order for Room Tags
pimpingootch
Hi Guys,
I have a question regarding Room Tags.  Is there a way to set the starting room tag number.  Example : When you insert the first Room Tag is starts as Default as 1.  Then when you tag every other room after the first one, they adjust automatically, 2, 3, 4 etc.
 My question would be, if there's a way to set the first Room Tag Number in the settings so that when I insert the first Room Tag it starts automatically at 101 and goes on to 102, 103 etc.
Thanks for the help Smile
Ben
Wed, Jul 29, 2009 at 8:35:09 AM | Starting Order for Room Tags
3.5 Stars: 395 Votes
Why don't you change your first room to 101 then see what happens when you insert the next room?
Thu, Aug 6, 2009 at 12:43:13 AM | Starting Order for Room Tags
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Like Hub said, once you set one number each one after that will be the next one in sequnce. So make sure you tag them in the order you want the numbers to go.
J. Allen Ball
Copy Architect's Room Tags?
Thu, Jan 31, 2008 at 1:08:41 AM
Opaque Room Tags
Thu, Nov 5, 2015 at 11:06:19 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Page generation time: 0.5476
