86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Families don't take materials while rendering
Wed, Jul 29, 2009 at 12:28:08 AM | Families don't take materials while rendering
radhikase
Hello,
I have a set of families, and I would like to assign materials to them for rendering. I tried the followed methods given below -
1.I edited each family, added a material parameter to each part/component. Given a value of <By category> to those parameters in the family. In the project, I have assigned a unique material to each component. But my rendering doesn't show the material.
2.I edited the family, assigned a material in the family itself. Once into the project, the family carried its material but still did not render with the same material.
Any one could guide me to understand what seems to be happening here? Any suggestions?
Thanks in advance,
Radhika.
Wed, Jul 29, 2009 at 7:54:57 AM | Families don't take materials while rendering
tim123
4 Stars: 19 Votes
Assuming that you have set up hte material parameters correctly. it could also be:
Revit can't find the maps for the materials if they're not from the standard library.  You need to map to each folder where you have mapping images in the render settings, found in options.
It could be a phase thing where the family is in a different phase,  It will then render to the object properties of that phase.
Thu, Jul 30, 2009 at 4:17:52 AM | Families don't take materials while rendering
radhikase
Hi tim123,
Thanks for your response, the problem sorted out. The problem was not with the families and their ability to take materials. I think the problem was with lights. The lights had a filter of a particular shade which made the rendering appear to be strange, without the materials in their real appearance. Once this was remedied, my rendering turned out pretty well.
Thanks again,
Radhika.
Sat, Nov 28, 2009 at 3:03:42 PM | Families don't take materials while rendering
slavapalooza
What setting did you change to remove the filter from the lights that were distorting your renderings?  I have been having a similar challenge with materials not appearing as intended.  Any insights would be appreciated.
Sat, Nov 28, 2009 at 3:22:05 PM | Families don't take materials while rendering
tim123
4 Stars: 19 Votes
Post an image of your rendering so that we can see what is happening.
Rendering materials within components
Mon, Apr 24, 2006 at 1:49:32 PM
Materials Don't Appear in Rendering
Thu, May 21, 2009 at 12:56:29 PM
Materials Wrong when Rendering Families w/ 3d CAD Imports RA2008
Fri, Sep 21, 2007 at 7:45:27 AM
This asset is shared with 13 other materials... and I don't like it.
Fri, Oct 18, 2019 at 8:47:38 AM
Basic Rendering Question: Are .bmp & .tiff images usuable for materials?
Thu, Oct 26, 2006 at 5:25:40 PM
Page generation time: 1.9327
